J.W. Winco has announced it now offers GN 115.10 Latches with Gripping Tray, Lockable, in metric sizes.
These RoHS-compliant latches with gripping tray are used in applications that require a molded recess in addition to the latching mechanism, e.g. if operating elements are not allowed to protrude for reasons of space. A rotary movement (limited to 90°) of the three-edged wedge moves the latch behind the frame, with the run-up bevels at the latch making it easier to close the door.
The front frame is zinc die-cast with either black plastic coated textured finish or silver textured finish. The tray is plastic, either gray or light gray. Latch housing is zinc die-cast, black plastic coated finish or chrome plated finish. Latch hardware is zinc-plated, blue passivated steel. Five types are offered: with triangular spindle, square spindle A/F 7 mm, square spindle A/F 8 mm, slot, or double bit. Twenty-two different latch arms cover the latch distance in a range from 4 to 50 mm.
J.W. Winco
jwwinco.com
Filed Under: Clamps, FASTENING • JOINING • locks • latches • pins
