ROLEC technoPLUS Enclosures Now Rated IP 69K For Jet Wash Protection
ROLEC technoPLUS enclosures are now available with optional IP 69K protection – safeguarding electronics from high pressure and high temperature jet washing.
They are designed for challenging indoor and outdoor locations. Each case features a dedicated bracket for horizontal or vertical mounting on poles and masts.
ROLEC technoPLUS enclosures are rated to IP 66 as standard (IP 67 and IP 69K optional) and molded from UV stable ASA Luran (UL 94 HB).
Each enclosure is pre-molded with screw ports for the mounting bracket so no machining is needed. They can be installed ‘lid closed’ to help protect the seal and the electronics.
Retaining straps hold the recessed lid in place if it does need to be opened – useful when the enclosures have to be installed at height or in other difficult locations. Hinged lid trims conceal the fixing screws to deter tampering and provide further protection against the weather.
ROLEC technoPLUS is available in five sizes ranging from 5.12” x 3.54” x 2.75” to 10.62” x6.69” x 3.54”. The standard color is light gray (RAL 7035). Custom colors are available on request.
Prices for technoPLUS start at $38. Accessories include the pole/mast attachment, terminal rails and an internal mounting plate.
Enclosures can be customized with CNC milling and drilling of cutouts; bespoke colors; printing and engraving of legends and logos; RFI/EMI shielding; assembly of components.
ROLEC
www.rolec-usa.com
Speak Your Mind
