Cellio is a total solution – providing cellular connectivity, hardware, software, and cloud storage, analytics, dashboarding, mobile apps, and alerts. Device Solutions next generation 4G LTE CAT1 enabled Cellio LoRa Gateway is for wide area, long range, end-to-end monitoring of agriculture, cold chain, gas distribution, transportation, and many other industrial (IIoT/M2M) applications. The Cellio solution is a total solution encompassing the hardware, software, wireless connectivity, cloud storage, and monitoring apps for smartphones.
As of mid-2018, Verizon has announced it will no longer activate 3G devices on its network and by end of 2019 will cease to support 3G devices (2G technology was sunset in 2016). Industrial customers looking for technology that will be supported for more than a decade will need 4G LTE products like the new Cellio Gateway. Until technologies like 5G are fielded, trialed, and scheduled for scaled deployment sometime after 2020, 4G LTE technology will be the primary technology supported by the major carriers. 4G LTE will be standard for at least the next 10-20 years for fielded applications and installations.
Cellio’s distributed architecture (star topology), with dozens of sensors attached to a Cellio transceiver, connects to the Cellio gateway. The Cellio Gateway makes the connection to the cloud through the cellular network. A single Cellio Gateway can support hundreds of transceivers on a campus, facility, etc. Leveraging a single cellular connection per site represents substantial cellular savings and overall lower Total Cost of Ownership (TCO) for enterprise-wide installations. For example:
Connecting multiple sensors to each transceiver, and possibly hundreds of transceivers to each Gateway, means that each sensor could be monitored for less than $1USD/mo inclusive of cellular fees, data hosting, dashboarding, analytics, mobile apps, etc. In contrast, alternative architecture approaches require a cellular connection for every asset (or every sensor) and can range upwards of $35/month – making many alternative approaches cost prohibitive for most clients.
In addition, Cellio Gateways are scalable and simple to deploy. Once deployed at a site, Cellio provides a platform onto which additional transceiver devices and sensors can be added very quickly, easily, and inexpensively. Cellio’s gateways provide a unique capability whereby the transceivers can simply be turned on and put into place and then automatically connect and start sending information to the Gateway which in turn relays the information to the Cloud. In practice, installations can be done in minutes with data showing up on the cloud dashboard almost instantly.
“With the pace of change in wireless standards and cellular network technology we value our partnership with a technology innovator such as Device Solutions,” said Lambert Matias, president and CEO, GovMobile, LLC. “We have been pleased with how rapidly we can deploy industrial-grade IoT solutions for our government clients using their Cellio Enterprise IIoT solution.”
The newest generation of Cellio 4G LTE CAT1 (with LoRa) Gateways provide:
• Internal cellular antenna
• Internal 900 MHz LoRa antenna – greater than 1 mile Line of Sight
• Internal LiIon back-up battery
• GPS Capable
• Single Gateway can support hundreds of Transceivers; each transceiver can support dozens of sensors.
• AC Power Supply (alternative power options available including solar)
• Waterproof and dustproof enclosure (IP68)
• 4G LTE CAT1 for both Verizon and AT&T (AT&T model includes 3G fallback)
Filed Under: IoT • IIoT • Internet of things • Industry 4.0, Infrastructure
