HO-3, HO-4 & HO-5: These multi-functional oils from Lubriplate can be used for bearings, gear cases, central lubricating oil systems, air compressors, hydraulic systems and chains.
These oils contain fluid zinc anti-wear additive, high aniline points for controlled seal-swelling characteristics, and excellent foam suppression properties.
Lubriplate
www.lubriplate.com
The post Heavy-Duty, multi-functional lubricating oils appeared first on Bearing Tips.
Filed Under: Bearing Tips
