Advantech launches FPM-200 Series industrial touch control monitors
By PR Editor | November 1, 2019
Advantech, a leading industrial computing platform provider, announced the launch of its FPM-200 series, a new generation of industrial monitors designed to provide premium display solutions at an affordable price.
Aimed at industrial and IoT applications, the FPM-200 series are true-flat LCD monitors that feature an IP66-rated front panel for protection from water and dust ingress. This ensures the monitors can withstand rigorous cleaning using high-pressure water jets, making them ideal for industrial environments with harsh operating conditions. Designed with the same slim, compact form factor as Advantech’s TPC touch panel computers for easy integration, the FPM-200 series monitors are equipped with 10-point multi-touch control functionality to offer a more lightweight display solution that can be conveniently operated. Furthermore, the display’s 16:9 widescreen aspect ratio provides a 40% increased viewing area compared to traditional 4:3 aspect ratio displays, thereby enhancing the overall visualization of information.
Regarding installation, like all of Advantech’s flat-panel displays, FPM-200 monitors can support various mount options, including panel, desktop, and VESA mounting, to ensure easy deployment in diverse industrial environments. Overall, FPM-200 monitors offer the best price-performance ratio for a reliable industrial-grade, touch-controlled display solution that can support a wide range of industrial and IoT-related applications.
Premium Industrial-Grade Quality at Affordable Prices
Featuring an industrial-grade design and IP66-rated true-flat front panel that protects against water and dust ingress, the FPM-200 series monitors can withstand 24/7 operation in industrial environments with harsh conditions, such as excessive vibration and temperature and power fluctuations. The IP66 rating for protection from dust and water ingress allows the entire display to be cleaned and easily maintained. Moreover, the monitors offer a backlight lifetime of 50,000 hours for an estimated service life of more than 5 years under constant load. Considering the hardware durability and service longevity, the FPM-200 series monitors offer very attractive and cost-effective industrial display solutions.
True-Flat Display with Multi-Touch Control
The FPM-200 monitors’ true-flat WXGA/full HD TFT LED LCD widescreen display features 10-point multi-touch control that supports two-handed operation for more intuitive input and increased efficiency. Multi-touch functionality also enables additional control features such as swipe and zoom gestures, predefined motion triggers, and two-point key confirmation, which can increase operational safety and boost productivity.
Key Features
• 15.6/21.5” WXGA/full HD TFT LED LCD with true-flat touchscreen
• 16:9 widescreen aspect ratio increases the viewing area by 40%
• 10-point multi-touch control via USB in Windows /Linux/Android OS
• IP66-rated front panel with chemically resistant glass surface
• Slim, compact design ensures easy installation
• Supports various mount options, including panel, desktop, and VESA arm
Of Advantech’s FPM-200 series industrial monitors, FPM-215W (15.6”) and FPM-221W (21.5”) are available for order now.
Advantech
www.advantech.com
Filed Under: Factory automation, Industrial automation, HMIs • operator interfaces • monitors
Tagged With: advantech
ADISRA InsightView-IV_main_dash2
ADISRA InsightView delivers advanced equipment analytics
Watlow’s POWERSAFE medium voltage thermal system
Portfolio
Packaging upgrades increase brewery’s efficiency
Passenger,Aircraft,On,Maintenance,Of,Engine,Repair,In,Airport,Hangar
HMI provides assist in aerospace forging equipment
