Advantech Receives Hazardous Location Certification
By Design World Staff | August 6, 2009
Cincinnati, OH — The Industrial Automation Group of Advantech announces that a wide range of their EKI family of Industrial Ethernet Switches and Media Converters have received Underwriters Laboratories (UL) Class 1, Division 2 (groups A, B, C, and D) certification for use in hazardous locations.
Installation of electronic devices in environments where flammable liquids, gasses and vapors may be present is a real challenge.  It is critical to use the right equipment in these environments.  With UL Class I, Division 2 certification, the EKI-2000 and 7000 series of products are now approved for use in hazardous environments, which are common to oil & gas, mining, and chemical processing industries.
The EKI family of Industrial Ethernet Switches are available in 5-port to 18-port configurations, with both standard copper and fiber connections, 10/100Mbps and gigabit (1000Mbps) speeds, and in both unmanaged and managed models.  Managed models offer manual port settings, advanced network traffic control, an ultra-fast 10ms self-healing ring for high availability, and remote monitoring capabilities.  The EKI Media Converters allow connections to be extended over optical fiber cable up to nearly 70 miles (110km) and are available in both 100Mbps and gigabit (100Mbps) speeds, with various types of fiber connectors.
Packaged in a compact and thin DIN-rail mount metal chassis, the EKI family of Industrial Ethernet products are ideal where panel space is limited.  They are also ruggedized for demanding industrial applications, with redundant 12 to 48 VDC power inputs, 4,000 VDC Ethernet ESD protection, power line surge (EFT) protection of 3,000 VDC, and feature standard -10 to 60°C or extended -40 to 75°C operating temperature range to ensure system uptime.
Currently, the following models are Class 1, Division 2 certified–Unmanaged Ethernet Switches: EKI-2528, EKI-2528I, EKI-2525, EKI-2525I, EKI-2525M, EKI-2526M, EKI-2526S, EKI-2528, EKI-2528I, EKI-2728; Managed Ethernet Switches: EKI-7559MI, EKI-7559SI, EKI-7656C, EKI-7657C, EKI-7758F; Ethernet Media Converters: EKI-2541M, EKI-2541MI, EKI-2541S, EKI-2541SI, EKI-2741F, EKI-2741SX, EKI-2741LX.
Advantech
www.advantech.com/ea
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
