Bearings that are mounted within a flanged housing are used when the bearing mounting surface is perpendicular to a shaft axis. They are commonly available in two, three, or four-hole configurations. Two-bolt flanged ball bearing units have a diamond or winged-shape with 2 holes for mounting. As with our 3-bolt Flanged Bearing Units, 4-bolt Flanged Bearing Units, and our Flangette Series, the 2-bolt flanged bearing units have bearings that can be moved and aligned to better accommodate long shafts.
Standard housings from AST Bearings include both cast iron and thermoplastic materials and come with built-in grease nipples.
AST Bearings
www.astbearings.com/two-bolt-flanges
Filed Under: Bearing Tips
