Metrol limit switches provide precision, repeatability and a long service life. Four new types of Metrol precision limit switches are now available from AutomationDirect.
The actuator of new sliding/angled offset limit switches detects objects traveling straight on or sliding into the actuator from an angle with 5-micron repeat accuracy. Metrol low contact-force limit switches are available with 5 or 10-micron repeat accuracy and an ultra-sensitive contact force of only 0.1 Newtons and are ideal for applications requiring extra sensitivity. High-vacuum resistance style limit switches with 3-micron repeat accuracy and an ultra-small design are an excellent choice for installations inside a vacuum, such as environmentally controlled manufacturing processes.
High-temperature stopper limit switches are rated up to 200° C and incorporate a mechanical stop along with the limit switch function, eliminating the need for a separate stop in many applications.
AutomationDirect
www.automationdirect.com
Filed Under: Sensor Tips
