Avoid Common Wireless Network Blunders
By Design World Staff | March 15, 2007
By Leslie Langnau
Although wireless networks are trendy, they have weaknesses. For one, they are inherently less reliable than wired networks. The popular 802.11 protocol, for example, loses data packets in a predictable and unavoidable manner, (see the sidebar The Disappearing Packet).“The quality of wireless networks is not the same as that of wired,” said Patrick McCurdy, product marketing manager, Phoenix Contact.
“Wireless reliability is not addressed as often as it should be,” agreed Bruce Hofmann, product marketing manager – advanced connectivity, Weidmuller North America. “Wireless signals are easy to block, especially by accident, and easy to disrupt or tap into. Reliability is a function of physics as well as what you pick for your radio or wireless controller.”
“Despite the inherent weakness of wireless, though,” continued Hofmann, “good reasons to use a wireless network include to replace cables, to cover long distance communication needs, setup a temporary or backup application, or get a process up and running quickly. However, I would convert to wired at the first opportunity.”
In this successfully developed wireless implementation, a full
artificial knee replacement wirelessly reports digital,
three-dimensional torque and force data back to computers. In an
Orthopaedic experiement, this second generation knee implant provides
twisting, bending, compressive, and shearing load data that occurs
across the human knee. These data will provide key input for new
products, techniques for implantation, and actual use of knee
replacements.
The wireless microsensors, from MicroStrain, enabled this breakthrough
with their micro-miniature, micro-power, and multi-channel strain
measurement technology. Using the 802.15.4 protocol, batteries are
eliminated. The remote powering coil is secured to the outside of the
patient’s shin, away from the knee. Using a wireless antenna, the
implant transmits digital sensor data to a computer in a readable
format. Data from the twelve strain gauges are sent to a computer,
which uses a stored calibration matrix to convert the raw strain data
into 3-D torques and forces about the knee.
Therefore, to smooth design and implementation, avoid these common pitfalls.
Tools. This pitfall should be common sense, but engineers often don’t have the right tools. “Typically these tools include a spectrum analyzer, network analyzer, and perhaps an RF generator,” noted John Schwartz, technical support manager Maxstream, Digi International. “It’s also a good idea to have some expertise in RF too.”
Remember, RF is inherently analog. “Even though you hear terms like digital modulation and digital radios, transmission and data reception travel along analog paths,” continued Schwartz. “In particular, the need for modulation devices is often overlooked in wireless systems signaling over the Ethernet protocol.”
Chips or cards. Select the specific wireless technology for an application and choose how you will incorporate it in the device or equipment. The options include chip sets, wireless cards, and network modules.
At the microprocessor level, wireless chip sets are a cost effective choice for small lot quantities. Plus, they help tailor the device to specific application needs. One pitfall to watch, though, is device driver integration. Often, the selected drivers are incompatible with the bus structure. Don’t assume that you are working with a PCI interface. Another pitfall is the pace of technological change. The life cycle of a chip set may be only two or three years, and therefore obsolete before the product goes to market.
Rather than chip sets, consider wireless cards, such as PCMCIA or CompactFlash cards. “We’ve had people integrate PCMCIA cards into a machine, said Gary Marrs, senior field application engineer, Lantronix. “You buy an off the shelf PCMCIA card, and embed them into a machine. You design backwards to make your real-time operating system work.” An advantage of this option is that it is easy to achieve higher power output and the card manufacturer must obtain the necessary FCC approvals. Plus, the card’s life cycle is the responsibility of the manufacturer. A disadvantage is that the driver must be ported to the operating system.
A third option is to use wireless network modules. You need not worry about end of life notices, and FCC approval is often a matter of paperwork rather than testing. Several companies are starting to offer wireless modules. “They make it easy to add wireless,” continued Marrs. “Some will provide a simple serial interface for receipt and transmission of serial data off the microprocessor.” Depending on the module, it can replace the RS232 port and transmit UART data for 802.11 connection.
“If you are working for a small, targeted customer base of one-half a million users or less, consider RF modules. RF circuit board components change so fast that a module saves the headache of trying to be current,” noted Schwartz.
Know the environment. A common blunder is the failure to ask important questions, such as: Where will the wireless devices and network be deployed? What are the obstructions? What is the location of metal machinery? “The location determines the frequencies you can use,” said Schwartz. “For example, if you need to penetrate through several walls in a building, in the US you can select the 900 MHz band.”
Site surveys can be crucial and eliminate many potential problems that could obstruct, limit, degrade, or bounce RF signals.
Match impedance
. “With RF frequencies, printed circuit board traces become a significant percentage of a wavelength,” said Schwartz. “Wavelength equals the speed of light divided by the frequency. One wavelength of a 2.4 GHz signal is about 1/3 meter or 1 foot long. Therefore, a 2-in. trace on the board equals 1/6 wavelength, which could reflect or emit signals like an antenna. Consequently, board trace dimensions are considered to be transmission lines and have characteristic impedances, so every input and output port or coupling in the RF path should be impedance matched.”
And don’t forget to consider static. “RF receivers can pick up incredibly weak signals in the microwatt region, which is a benefit,” said Schwartz. “However, they are also susceptible to electrostatic discharges.”
Antennas. Unclear signals is an RF phenomenon that can often be resolved through proper antenna configuration. Be sure the circuit matches the impedance of your choice. “Distance can become a challenge,” said McCurdy. “In large areas, you can line up several antennas and achieve good success, but you need the right accessories and correct impedance-matching connection cables so that you don’t attenuate the signals.”
Watch antenna placement. Any metal placed close to an antenna, to within some fraction of a wavelength, will tend to couple to that antenna and act as part of it. “It’s the near field effect,” added Schwartz.
Another problem arises with multipath interference when the signal from a transmitter takes more than one path to the receiver. “Directional antennas will clear this problem,” added Marrs. Other options are an antenna hierarchy that focuses the radiated signals or repeaters.
The XPort Direct is an embedded device
gateway that lets most electronic devices with a microcontroller based
serial interface connect to a network. From Lantronix, serial data from
the microcontroller’s CMOS logic-level serial port is put into packets
and delivered over an Ethernet network via TCP or UDP data packets. The
XPort Direct includes an x86 class 16-bit network processor SoC, 256 KB
of zero wait-state SRAM, an Ethernet 10/100 MAC/PHY along with Flash
memory, and an RJ45 jack that incorporates LEDs for link and network
activity indication.
The disappearing packet
The 802.11 protocol is the basis for thousands of wireless networks.
VeriWave Inc., a firm testing this protocol recently discovered that it
has a flaw—about 0.001% of data packets disappear. The firm noted that
this degree of packet loss is predictable and unavoidable. The flaw
occurs when the network tries to resend dropped packets. Any network
can experience lost packets, however, error-checking and retransmission
mechanisms should reduce the chance to as near zero as possible.
The physical layer convergence procedure (PLCP) header seems to be the
problem. The 32-bit cyclic redundancy check (CRC) guarantees that
packets arrive at the destination uncorrupted. The PLCP header, though,
has only one bit for error checking, making it more vulnerable to
corruption, as though there is a “blind spot” where retries are not
seen by the protocol.
VeriWave presented this information to the IEEE committee last year.
The 802.11n protocol standard may be revised to correct this flaw. The
802.11 versions a, b, and g, however, remain vulnerable to it.
Frequency selection. In the U.S., choices include 900MHz, 2.4GHz, and 5GHz. These fall into the industrial, scientific and medical (ISM) band. The 2.4GHz band is the most widely used, and the most crowded. It is essential to check how many other devices in the desired area also operate at this frequency.
“If your network will remain within a building, 900MHz may be just fine,” noted Schwartz. “At this frequency, you will have about 28 MHz of available bandwidth. The 2.4 GHz in the US goes from 2.4 to 2.4835, so you have 83.5 MHz available.”
The 802.11 protocol is usually placed at the 2.4GHz level. If there are multiple 802.11 networks in the application, it may not be desirable to add more, especially if channel control is not available.
Part of the choice is based on whether the application needs to move small amounts of information a long distance or large amounts of information a short distance. “The speed desired on an 802.11 application,” added McCurdy, “isn’t available with 900MHz because of the modulation techniques used for the 802 protocol.”
An option is to use the 5GHz band. It sits above all the noise of the 2.4GHz range. “If you need the speed of a fast network but not the interference, try the 5GHz frequency range,” added McCurdy. “However, there are more installation challenges at the higher frequencies. You won’t necessarily obtain the same distances, and line of sight is important.”
But the 5 GHz band can be used internationally. Other factors to consider with these frequencies include:
• Most 900MHz devices are proprietary technology.
• The 802.11 protocol has fewer interoperability concerns.
• The law limits wireless applications to 100 mW of power.
RAD-Link Software, V 3.0 is a Windows-based Serial Data Radio
programming software with a network setup wizard and network monitoring
system. From Phoenix Contact, the setup wizard uses a tree structure
that lets users see the name of each radio and review which slaves are
communicating with the master and which slaves are communicating
through repeaters.
The 802.11 family of wireless protocols
The 802.11 protocol provides 1 or 2 Mbps transmission in the 2.4 GHz
band using either frequency hopping spread spectrum (FHSS) or direct
sequence spread spectrum (DSSS).
The 802.11a provides up to 54 Mbps in the 5GHz band and uses an
orthogonal frequency division multiplexing encoding scheme rather than
FHSS or DSSS.
The 802.11b provides 11 Mbps transmission (with a fallback to 5.5, 2
and 1 Mbps) in the 2.4 GHz band. It uses only DSSS and its capabilities
are comparable to Ethernet.
The 802.11g provides more than 20 Mbps in the 2.4 GHz band.
Transmission speed
. “The Ethernet protocol always kicks down to the slowest reliable speed,” said Hofmann. “If the application calls for 100 MB cards, and only one device transmits at 10 MB, then the entire network will drop down to that rate to avoid collisions. Ethernet does this automatically.”
Also, consider the hand off among multiple wireless devices. In automotive applications, for example, transponders on vehicles record data at each assembly station. As the vehicle moves from one station to the next, it may encounter a signal dead zone and stop the line. To prevent this, you can use an optional but little known feature of IEEE 802.11i identified as fast roaming. “As a vehicle moves down the line, a client radio or device talks to the access points. As it moves away from one point, it starts the authentication process to identify itself with the next radio, eliminating lost time,” said Ira Sharp, wireless product specialist, Phoenix Contact. “Anytime you have devices moving, consider fast roaming.”
Power. Wireless devices tend to consume more power. This is a particular issue with wireless sensor networks (WSN), which are often used in predictive maintenance applications that cover large distances. Most WSN devices operate from battery power. The attached sensors conserve that power by transmitting a signal only at a state change. A widely used protocol for this is IEEE 802.15.4.
Plan for growth. Design the ideal system. “You may not deploy all the components immediately,” said Hofmann, “but set the foundation for them. You’re going to add to it once you work with wireless and see how cool it is. You will find a range of projects that wireless can handle. Fortunately, these networks are flexible and can be expanded easily.”
Topography. In industrial applications, the preferred topology is master slave. However, in wireless, a mesh layout works best. Mesh layouts allow all wireless devices to communicate with each other. “The setup is time consuming and an effort in reasoning,” said Hofmann. “If done right, though, you can set up self-healing rings where a signal can travel around a downed segment.”
The FCC. A large blunder is not obtaining required agency approvals. FCC approval, which is not guaranteed, is still needed even with the license free ISM bands. “If there’s too much RF noise, too much power output, then you have to go back to the drawing board,” noted Marrs. “They still police the spectrum, and they try to keep a level playing field to avoid the introduction of devices that overpower others.”
The government also imposes restrictions such as the maximum effective rate of power, which is limited to 4W. “Technically, you could push through more, but legally, the FCC won’t allow it,” noted Hofmann. So far, engineers are working around the regulatory imposed limitations with repeaters, antennas and gateways among other devices.
Weidmuller’s WI-I/O 9-1 provides almost
instant I/O connection over plants or process facilities. It contains a
microcontroller, I/O circuits, radio transceiver, encrypted security,
configuration ports, and integrated power supply. It is a rugged low
cost alternative for expensive signal wire installations over short or
long distances to 20 miles.
Application Interface Protocols. “In industrial applications, you don’t have to use Ethernet. There are different types of wireless radio signals that use different protocols,” noted Hofmann. It is only Ethernet’s dominance in industrial applications that make it so widely used. However, interoperability issues are the same as those of wired networks.
Often overlooked, serial-based legacy network systems can disrupt a wireless implementation. The wireless system may need to transmit that serial data, which not all RF modules handle.
Other tips include, have a good ground plane and control power routing. Use a star configuration where possible, not a daisy chain. On a circuit board for example, the power module would be central and connect individually to each component needing power.
And, in all of these recommendations, be aware of the limitations of commercial grade RF products, which were not suited for noisy industrial environments.
Phoenix Contact
Weidmuller
MicroStrain
Digi International
Lantronix
VeriWave Inc
:: Design World ::
Filed Under: Wireless, Computer boards, Data acquisition + DAQ modules, Networks • connectivity • fieldbuses
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
