The new Bahco Easy-Cut Bimetal Portable Bandsaw Blades for hand-held machines are ideal for cutting all common materials. In addition, to fast cutting, the unique, patented Easy-Cut blade configuration eliminates the need to specify tooth pitch or type. Also, it reduces the number of different blades from twelve to two, a great benefit for distributors and end users alike.
The blades feature easy feeding, good control, and precision cutting for a variety of materials, including: bronze, copper, mild steel, aluminum, brass, chrome and others. These blades cut all materials commonly used in construction: conduit, galvanized and PVC pipe, rebar, angle iron, wood, virtually any material, all without changing the blade.
Two lengths of the bandsaw blades, both with EZ tooth types, are available:
Product code PBEZ835 measures:
- 1/2 x 0.02 in., or 13 x 0.05 mm
- Length, 32 7/8 in., or 835 Marlene:
- Available in 1, 3, or 100 pack quantity, and
Product code PBEZ1140 measures
- 1/2 x 0.02 in. or 13 x 0.05 mm
- Length: 44 7/8 in., or 1,140 mm
Bahco, a manufacturer of cutting tools, pioneered the bimetal saw blade which melds two different metals into one blade while incorporating the best characteristics of each.
www.snaponindustrialbrands.com
Filed Under: Green engineering • renewable energy • sustainability
