According to OSHA, 35% of all injuries to contractors are the result of falls. One solution to reaching when you should not may be in the Spray-flex. The developer says:
- Spray-flex keeps you from working with your arms over your head, allowing you to keep your balance better.
- Spray-flex saves your back and shoulders. No more awkward positions which put your at risk for injury.
- Spray-flex keeps you dry… which means no more slips!
So what exactly is Spray-Flex?
Spray-Flex is a flexible attachment for the end of a pressure wash gun that allows you to direct the flow any direction you like.
Bend It. Twist It. Turn It. 90° flexibility ~ Works with any pressure washing wand and tip and holds its shape up to 5,000 psi.
The Spray-Flex system is a significant development for to the cleaning industry. The device is said to let one person wash the surfaces of a two-story building from the ground, with a spray angle that works for whatever the job requires.
Filed Under: Green engineering • renewable energy • sustainability
