New Hyde Park, NY — A video from Advanced Antivibration Components – AAC shows the superior isolation effectiveness achieved with their soft silicone gel based products for isolating equipment, instrumentation or components.
At the updated AAC updated online eStore you can download 3-D CAD models, request a quote, check stock and view catalog and technical pages. AAC stocks a wide range of antivibration and shock isolation products which include: stud & nut type mounts, base plate fastened mounts, wheels, leveling & foot mounts, suspension mounts, spring, steel mesh & cable mounts, bumpers, shock absorbers & channel mounts, bushings & grommets, pads & tapes, and couplings. These products are stocked in different materials including: rubber, neoprene, urethane, Sorbothane®, stainless steel mesh and springs. Many are suitable for use in extreme environmental conditions. Of special interest is a complete selection of Silicone Gel floor mounts, pads, sheets, plus paste-type thermal gel.
AAC stocks a wide range of silicone based isolators ranging from: base mounts, spring silicone mounts, silicone bushings to attenuate micro vibrations and shock on pc boards, disc drives and consumer electronics. Other silicone products include gel pads, tape, chips, foam and a series of thermal conductive isolators which dissipate heat while they absorb shock. The AAC Youtube Channel can be viewed at: http://www.youtube.com/user/vibrationmounts
http://vibrationmounts.com/NewProducts/SiliconeMountsVideo.htm
Filed Under: Assembly, Automation components, Materials • advanced, Shocks + vibration control • gas springs
