The Z-Compact mini terminal block series includes the ZDU 2.5 N, a single-level feed-through terminal, and dual level versions, including the ZDK 2.5/3 AN. When the 1.4 in. (length) single-level block is mounted on a TS-35 DIN-rail, sixty termination points per foot are possible. It has one pluggable jumpering channel per block and comes in three or four branch configurations. The dual level, ZDK 2.5/3AN, has six connections and two jumpering channels. The blocks are designed for space restricted control cabinets and standard junction enclosures.
Weidmuller
821 Southlake Blvd.
Richmond, Virginia 23236
Tel: (804) 794-2877
Fax: (804) 379-2593
Web: www.weidmuller.com
About Weidmuller
Weidmuller is a leading supplier of control and automation connectivity solutions, such as Industrial Ethernet Solutions, Power Delivery Solutions, Design-Build-Deliver Solutions, Complete Rail Solutions, switching technology for control panels, printed circuit board terminals and connectors, and terminal blocks.
:: Design World ::
Filed Under: Terminal blocks
