Capital Safety improves four good products
By Paul Dvorak | July 11, 2013
Capital Safety, home of the DBI-SALA and PROTECTA brands of fall protection equipment, recently expanded four of its product lines:
  • PROTECTA PRO Welder’s Harness,
  • PROTECTA 20-foot Rebel Self Retracting Lifeline (SRL),
  • DBI-SALA Sealed-Bok SRL, and
  • DBI-SALA Suspended Workman’s Chair.
The Welders Harness resists heat bursts and weld splatter. For instance, the webbing can withstand char temperatures up to 700°F.
the Welders Harness resists heat bursts and weld splatter. Specifically, the webbing can withstand char temperatures up to 700°F
The PROTECTA PRO Welders Harness endures harsh welding environments. Featuring Modacrylic over Kevlar and Polyester webbing that is heat resistant and flame retardant, the Welders Harness resists heat bursts and weld splatter. Specifically, the webbing can withstand char temperatures up to 700°F, absorbing heat and lasting longer than the standard harness. With a lightweight design that significantly improves comfort and a 420-lb user capacity, the Welders Harness is an affordable, economical option for workers who weld at height.
The latest PROTECTA Rebel cable SRL retains all the benefits of a Rebel in a lightweight 20-foot version, ideal for commercial and residential construction and refinery maintenance. With compact, durable thermoplastic housing—stackable on work surfaces—and an ergonomic carrying handle, it’s easy to transport, set up and store this lightweight SRL. The new 20-foor SRL expands the Rebel cable line to include lengths from 20 to 100 ft. Additionally, the side cable exit design enables smooth operation and reduces cable wear.
The DBI-SALA Sealed-Blok family—a comprehensive line of sealed SRLs in the industry—recently extended its product offering with the addition of a 175-ft SRL. The Sealed-Bok series now includes SRLs ranging from 15 to 175 ft. Featuring heavy-duty, durable aluminum housing and stainless steel end-plates, the 175-ft Sealed-Blok SRL delivers superior sealed performance, resisting water, contaminants and even corrosion. Dynamic components are safely sealed inside the IP68-rated housing, making this SRL ideal for the toughest working environments, including offshore platform access in the oil and gas and wind energy industries. With a built-in carrying handle, certified as a secondary anchor point, the Sealed-Blok SRL is certified for “dropped objects” protection.
DBI-SALA Sealed-Blok family recently extended its product offering with the addition of a 175-ft SRL.
The new and improved DBI-SALA Suspended Workman’s Chair, specifically designed for suspension work applications on the edges of buildings, bridges, tanks or silos, provides enhanced comfort for prolonged work hours. Weighing a mere 9.9 lb, its lightweight design maximizes comfort and improves portability. With a 420-lb user weight capacity—the highest in the industry—the Suspended Workman’s Chair can support heavier tools and equipment than competing products, and the aluminum foot step feature relieves pressure off the user’s back and legs. Used with a complete backup fall arrest system, the Suspended Workman’s Chair helps to support, suspend, position or transport the user. These products comply with current OSHA and ANSI industry standards.
Capital Safety
www.capitalsafety.com
Filed Under: Renewable energy
Tagged With: capitalsafety
Solar Atmospheres partners with energy storage company
Material simulation, testing improve lifespan of offshore wind turbines
TEGAM announces the ultimate handheld meter – the Display Probe
Harting presents new wind solutions at HUSUM Wind
