Cellular IP gateways provides high speed transmission with simplified deployment
By Paul Dvorak | April 1, 2015
OnCell G3111/G3151-HSPA are cellular IP gateways can conveniently and transparently connect your existing Ethernet and serial devices to a 3G cellular network.
Consistent wireless access in a data transmission network comes with the adoption of HSPA technology for high speed transmission, a simplified deployment design for an easy-to-use experience, and industrial-grade performance. Moxa’s OnCell G3111/G3151-HSPA switches offers users the best price-to-performance ratio 3G IP Gateway. In addition, with the best price-performance ratio among competing devices makes OnCell series ideal for remote sites.
OnCell G3111/G3151-HSPA are cellular IP gateways can conveniently and transparently connect your existing Ethernet and serial devices to a 3G cellular network. With the integrated GuaranLink feature, you can be confident that your device will always stay connected or recovered from any unexpected interference. With Moxa’s industrial design, higher EMS level are tested to ensure the highest reliability for any harsh environment. The G3111/G3151-HSPA cellular IP gateways are the most compact, simple and robust industrial 3G solution. Universal band supports:
  • Five-band UMTS/HSPA 850/800, 900, 1900, 2100 MHz
  • Quad-band GSM/GPRS/EDGE 850/900/1800/1900 MHz Simple, Flexible, and Reliable
  • Ethernet/serial/cellular co-existance for simple and flexible communication
  • OnCell Central Management for private IP communication and centralized management
  • Industrial-grade design for high device realibility
  • GuaranLink for reliable cellular connnectivity
  • Download: Up to 14.4 Mbps
  • Upload: Up to 5.76 Mbps Plug-n-Play 3 way Communications (Cellular/Ethernet/Serial)
  • OnCell Central Manager for Private IP Solution and easy management
  • GuaranLink innovation for non-stop connectivity
  • High level of EMS protection with Heavy Industrial Grade certification
Moxa
www.moxa.com
Filed Under: Green engineering • renewable energy • sustainability
Tagged With: Moxa
