These new direct actuating valves offer extremely fast response time for accurate dosing of minute volumes with the same long life you expect from the original Clippard EV line of electronic valves, now in a 7mm cartridge package.
Due to very low moving weights, they are extremely quiet and emit very low vibration. Because of the small size and low energy consumption, they are also ideal for transportable and mobile systems. These valves can be fully customized according to the unique requirement. Consult Clippard with your specific application.
• Expected life of over 1 billion cycles (under certain conditions)
• Extremely small dead volume
• Low vibration and noise
Medium: Air, Gas or other Compatible Fluids
Nominal Power: 0.85 watts
Switching Time: Temperature Range: Up to 122°F
Electrical Connection: 3” Wire Leads
Voltage: 12 or 24 VDC
Mounting: Cartridge
Weight: 1.4 oz.
Wetted Materials: Stainless Steel
Seal Material: FKM or EPDM standard. FFKM available upon request.
Clippard Instrument Laboratory
Filed Under: Valves, Pneumatic Tips
