Clippard introduces Cordis CP1 single-valve dynamic pressure controls
By Rachael Pasini | February 16, 2023
Known for reliability, innovation, and focus on miniature pneumatics, Clippard’s Cordis Pressure Controllers use the proven EVP and DVP proportional valve series allowing for steady, accurate, and repeatable downstream pressure control as demand or process changes. The result is a very precise linear pressure control within a closed-loop system providing ultra-high resolution and repeatability.
Two Clippard Cordis CP1 pressure controls in front of an abstract background.
Clippard’s Cordis CP1 pressure controls are designed for precise, linear pressure control within a closed-loop system and for ultra-high resolution and repeatability.
The Cordis uses a microcontroller, an internal pressure sensor, and a Clippard proportional valve. The inlet valve is connected to the moderately regulated supply pressure. Once a command is increased, the proportional valve opens up to allow supply pressure to pass over the sensor element, which provides active feedback for the microcontroller to satisfy the set point in the process. If, at any point, the sensor detects a value higher than the set point, the proportional valve closes and allows the process to consume the remaining downstream pressure.
Feature include:
  • Smooth linear control
  • Integrated internal feedback
  • Multiple flow configurations
  • Dynamic proportional pressure control
  • Non-pulsing proportional fill
  • Customizable pressure ranges
  • Multiple inert gas compatible
  • Customizable Calibrated Ranges
Clippard
clippard.com
Filed Under: NEWS • PROFILES • EDITORIALS, Pneumatic equipment + components
Tagged With: clippard
Rachael Pasini
Rachael Pasini is the editor-in-chief of Design World, covering industrial automation technologies, advanced materials, fluid power, additive manufacturing, and more. She also supports engineering leaders and managers in developing and sustaining innovative teams. Rachael holds a master’s degree in civil and environmental engineering and a bachelor’s degree in industrial and systems engineering from The Ohio State University. With nearly two decades of technical writing experience, along with trade journalism and teaching college math and physics, she is passionate about educating individuals and building supportive engineering communities.
