Compact, Multi-stage Venturi Vacuum Pumps
By Dave Miyares | February 10, 2010
Hudson, MA — Anver Corp. announces a line of compact, multi-stage venturi vacuum pumps that use low air pressure without sacrificing performance, for use in a wide range of automation applications.
Anver Air-Miser™ MSP-AM Series Multi-Stage Air-Driven Vacuum Pumps feature an internal design which requires only 45 psi (3.1 bar) air pressure, about half that of conventional venturi-style vacuum pumps. Ideally suited for a wide range of automation applications, they provide a reliable 100% duty cycle with performance equal to conventional pumps and run quieter.
Made from anodized aluminum with brass nozzles, Anver Air-Miser™ MSP-AM Series Multi-Stage Air-Driven Vacuum Pumps are offered in five sizes from 0.06 to 0.64 SCFM @ 24” Hg and measure 3.78” L x 1.26” W x98” H (96 mm x 32 mm x 24.9 mm), include a 2.76” tall x 1” W (70 mm x 24 mm) muffler, and are offered with adapters for G to NPT attachment.
Anver Air-Miser™ MSP-AM Series Multi-Stage Air-Driven Vacuum Pumps are priced from $115.00 ea., depending upon model. Literature and price quotations are available upon request.
Anver Corporation
www.anver.com
Filed Under: Factory automation, Fluid power, Pneumatic equipment + components, Pumps
Solid-state relay characteristics and applications
