Compact safety magnetic sensors
By PR Editor | January 2, 2020
The MC36C Series Compact Safety Magnetic Sensors are for safety-related applications, such as the monitoring of swinging, sliding or removable safety guards, which keep personnel safe from dangerous areas. The MC36C Series of magnetically-coded REED safety magnetic sensors monitor the position of sliding, hinged and removable safety guards, especially in dirty and dusty environments. Because of their wide actuation range, the MC36C magnetic sensors handle applications where great tolerances are required, such as with safety gates or doors that are imprecisely aligned.
The MC36C Series are versatile and can work as standalone or in conjunction with a safety module to reach a safety category 4, according to the EN ISO 13849-1 Standard.
These are some of the features which make these sensors flexible to meet various application requirements:
Compact size (36 x 26 x 13 mm)
Output configuration (2 NO or 1 NO and 1 NC),
Availability with 2m cable or M8 quick disconnect (left or right exit).
Other important features include:
Assured switching range: 5 mm w/MC36CM
Assured switch-off range: 15 mm w/MC36CM
Operating temp.: -25 to +80°C (-13 to 176°F)
Rated operating voltage: 12-24 Vac/Vdc
Rated operating current: 0.25 A (resistive)
Maximum switching load: 6W (resistive)
Maximum operating frequency: 100 Hz
Optional LED indication
Degree of protection: IP67
CE and cULus approved
The MC46C safety magnetic sensors are for non-contact detection and are suitable to monitor safety gates that prevent the entry of personnel in the vicinity of dangerous machines in motion, such as conveyors, robots, mechanical links, etc.
Carlo Gavazzi
www.carlogavazzi.com
Filed Under: Sensors (position + other)
Tagged With: carlogavazzi
Subsea position sensing solutions
quanergy
Smart lidar targets collision avoidance, smart navigation for mobile robots, port automation, warehouse logistics apps
Heilind Electronics signs distribution agreement with Crouzet Mechatronic Components
Balluff sensor with Siemens controller provides accurate positioning to 250 meters
Going small with 3D printing
