Creating better materials for renewable fuels
By Paul Heney | February 15, 2019
FST fuels and sealsE-fuels are expected to improve the climate footprint of conventional powertrains. New findings in material research by Freudenberg Sealing Technologies show the impact that OME (oximethylene ether), a substitute for diesel fuel, has on the long-term stability of seals. The research has found that seals made from an already widespread material, fluoro rubber (FKM), are basically suited for renewable fuels. But there are surprisingly large differences between specific FKM varieties.
The automotive industry is not simply betting on electric powertrains as a way to reduce CO2 emissions from road vehicles. Even conventional internal combustion engines are expected to become more climate-friendly, thanks to e-fuels. They are liquid or gaseous vehicle fuels that are not refined from fossil petroleum — but instead are created from carbon and hydrogen with the help of solar and wind energy.
They can be mixed with conventionally produced fuels, bringing a reduction in CO2 emissions if the carbon employed is either extracted in advance from the air or from unavoidable industrial emissions. Until now, there has been very little experience with the effects of the new fuels on the long-term stability of seals in fuel systems.
Freudenberg has now explored the behavior of sealing materials that are exposed to OME in exhaustive testing for the first time. The fuel used in the tests consisted of mixtures of standard diesel fuel and OME, which was present in concentrations ranging from 10 to 30% of volume. Other tests were carried out with pure OME and with 100% fossil diesel fuel as references.
The volume expansion and the change in mechanical strength of various sealing materials, namely FKM with different levels of fluorine content, FFKM, NBR and EPDM, were measured. In line with industry standards, they were stored for 168 hours at a temperature of 125° C in the test media. Additional exposure tests were carried out with specific fuel combinations over a period of 1,000 hours so long-term effects could be studied. The more the material swelled over this period, the lower its strength, which becomes especially clear from a decline in elongation at break.
Why do experts immediately turn to relatively expensive polymers such as FKM in the evaluation of a new fuel system? According to Dr. Boris Traber, the head of Global Material Development at Freudenberg Sealing Technologies, “Fluorine atoms are significantly larger than carbon atoms, so they form a kind of protective shield for the seal’s basic material,” he said. “Fluorine-carbon compounds are also highly symmetrical, which neutralizes their charge concentration. The effects that we were able to observe are not unlike a coated pan upon which both water and grease form droplets.”
Carried over to fuels, this shields the nonpolar ingredients such as hydrocarbons and the polar ingredients such as water and ether, which leads to less swelling.
The results even surprised the experienced material experts: In nearly all of the seal materials that were tested, pure OME led to volume expansion that far exceeded the usual swelling values. The image that emerged in FKM compounds was one surprise: it was expected that the swelling volume would decline with rising fluorine content. But that wasn’t the case. The expansion in volume was not linear in relation to the fluorine content.
This anomaly can be traced back to a correlation with hydrogen content in this kind of FKM. A higher proportion of hydrogen also leads to high swelling values. Accordingly, the perfluoro rubber (FFKM) that was tested exhibited very good values as well, although it is significantly more expensive than other options. An EPDM also showed low swelling in pure OME.
The test series also showed that the tested FKM materials showed a much lower level of swelling in an admixture with up to 30% OME by volume, an encouraging result.
“We could immediately substitute OME for a certain share of fossil diesel fuels,” said Traber. “But our experience shows that — especially outside of Europe — actual fuel quality can fluctuate greatly due to uncontrolled impurities. So, experts should always be consulted during the selection of sealing materials.”
The FKM materials proved to be superior in all the test series. It was not just the fluorine content but rather the entire material structure that was crucial for strength and leak tightness. As a result, Traber sees no fundamental obstacle to the introduction of renewable fuels: “Even today we have suitable materials available if the configuration is right.”
www.freudenberg.com
Filed Under: Green engineering • renewable energy • sustainability, MOTION CONTROL
Tagged With: freudenbergsealingtechnologies
Paul Heney
