Crystal Instruments’ Spider-81 Vibration Control System
By Natasha Townsend | June 8, 2012
Spider-81 is a highly modular, distributed, scalable vibration control system with centralized DSP architecture and simple operation via PC, Wi-Fi enabled PDA or iPad.
Unlike traditional controllers that rely heavily on an external PC for real-time operation, Spider-81 is the first controller to directly integrate time-synchronized Ethernet connectivity with an embedded DSP centralized architecture. Its patented dual A/D design allows it to achieve a true 130 dB input dynamic range. Each measurement channel can detect signals ranging from 6 µV to 20 V, with a design that completely eliminates the need for the input range or gain settings found on traditional controllers. Integrated with an IEPE output, charge amplifier, ac/dc coupling, and Transducer Electronic Data Sheet capabilities per IEEE P1451.1 standards, it facilitates usage within larger channel count applications. Its unique floating ground design significantly reduces potential EMI/ground loop interference during installation. The incorporation of safety routing allows for transducer failure detection within milliseconds, ensuring quick troubleshooting of measurement error sources. Built-in isolated digital I/O and RS-485 serial ports also allow for easy interface with other hardware. A ten-pin D-SUB connection allows for independent monitoring of analog signal on both inputs and outputs.
The hardware includes voltage, charge, and IEPE transducer inputs. The system’s internal flash memory stores test configuration data for control of up to hundreds of channels simultaneously with real-time analysis and recording.  A bright LCD display allows for real-time data testing status, such as control RMS or sweeping frequency, to be instantly viewed. An internal battery backup system allows for continued controller functionality and data saving, in the event of a network or power loss, ensuring fail-safe operation.
Built on IEEE 1588 time synchronization technology, Spider-81 allows modules on the same network to be synchronized with up to 100 ns accuracy, for a guaranteed ±1° cross-channel phase match of up to 20 kHz. With such unique technology and high-speed Ethernet data transfer, network distributed components truly act as a single, integrated system. One PC can monitor and control multiple controllers over the network. The Spider-81 “Black Box” mode also allows it to operate without a PC, either according to a preset schedule, or from a variety of external devices, such a Wi-Fi enabled PDA or iPad. In addition, it is fully compliant with industry standard ASAM-ODS data and file models. Since all control processing and data recording are executed locally inside the controller, network connection won’t affect controller data collection speed or integrity.
Crystal Instruments
www.go-ci.com
Test & Measurement Tips
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
