Elmo Launches Super Compact Servo Drive for 480VAC
By Patrick Curran | March 4, 2015
Elmo Motion Control will introduce at the SIAF exhibition the new “smallest on earth” servo drive that operates directly from the 480VAC at SIAF 2015, Guangzhou, China, on March 9-11, 2015.
Delivering 10A continuous at up to 480VAC with size of only 72mm x 140mm x 110mm makes the G-OBO10/480 the smallest servo drive to deliver >5KW from 480VAC mains connection.
Elmo-Motion-Control-Elmo-Motion-Control-Gold-oboGold-obo
The unique characteristic of using high current loop dynamic range with resolution ratio of 1/2000 enables a huge flexibility and proven to improve dramatically the performance of linear and torque motors operating in demanding high-end applications. Those applications require very high current control for high acceleration rates and low current control for very smooth and slow speed process operations. The current control precision and accuracy is uncompromised in both extreme operating conditions.
The ratings of GOLD OBOE are 13A/270VAC, 3A/480VAC, 10A/480VAC.
The G-OBO is complementary drive to Elmo’s Gold Bassoon (up to 10A/270VAC) and the Gold Tuba (up to 40A/480VAC). Being so small, very efficient and rugged is a huge space saver and allows mounting “anywhere”, in the machine, next to the motor, on the moving load, and thus saving costs of cabling, wiring, electrical cabinets, etc.
Elmo Motion Control
www.elmomc.com
Motion Control Tips
Filed Under: Motion Control Tips, Motors (direct-drive) + frameless motors
Tagged With: elmo, elmomotioncontrol
New gearboxes for electric motors in mobile machines
Leading motion-control and actuation options for robotics
Basics of wave and cycloidal gearing for robotics and servo designs
New micro servo-drive system for extra-low-voltage manufacturing applications
