Catering to Original Equipment Manufacturers (OEM) and Maintenance, Repair and Operations (MRO) markets around the world, Emerson Bearing Boston has added Interchanges and Technical Solutions libraries to their “Technical Toolbox” on their website, EmersonBearing.com.
Whether conducting research or making sure measurements are correct, Emerson Bearing’s detailed Interchanges library, which is now part of the company’s online Technical Toolbox, provides a list of interchanges in one easy place.
Emerson Bearing has also added a Technical Solutions library which delivers 30 different resources with information on bearing training, setup for different types of bearings, bearing usage guides, and other industry solutions. Within the library of Technical Solutions, customers will find eBooks, charts and data sheets such as “Improving Speedability in Ball Bearings”, “Fixed and Floating Bearings Explained”, and “Proper Practice for the Cleaning, Mounting and Removal of Bearings”.
Emerson Bearing’s Technical Toolbox is a portal to a library full of charts, guides, posters and helpful ebooks about bearings in all forms. Guides such as Bearings 101, Bearing Failure Analysis, Nomenclature, Bearing Maintenance, Super Precision Bearings, and Conversion Chart as well as a CAD Library, the Art of Precision Bearings webinar, infographics, vendor catalogs and more may be found in this section.
In addition to the Technical Toolbox, Emerson Bearing provides 24-hour service, same day delivery, customized kitting and more. Their experts can assist OEM and MRO in determining which bearing technologies would be most suitable by taking into consideration the specifications, recommendations, maintenance strategies, fatigue life and wear resistance of bearings in relation to the application.
www.emersonbearing.com/technical-toolbox
Filed Under: Uncategorized
