Emerson Bearing Boston, a bearing company catering to Original Equipment Manufacturers (OEM) and Maintenance, Repair and Operations (MRO) markets around the world, announces an expanded line of Oil Seals, specifically, Bearing Isolators.
Emerson Bearing’s expanded line includes Garlock brand isolator-style oil seals, which areavailable in metal and non-metal materials, feature a single-piece design, and do not place excessive stress on shafts. Isolator-style oil seals provide an ideal solution for severe applicationsand are easier to install than inch measurement oil seals and metric oil seals.
Steve Katz, president of Emerson Bearing explained, “Essentially, oil seals close the spaces between stationary and moving parts in order to reduce the risk of lubricant release. They are used in various manufacturing applications, including those found in automotive manufacturing, engine manufacturing, off-highway jobs, oil refineries, and power transmission.”
Oil seals are critical components that help keep equipment from breaking down, and allow production equipment to better withstand severe environments. Oil seals help ensure consistent, reliable operation without the risk of damage from leaks.
Isolator-style oil seals provide outstanding protection, including high abrasion resistance as well as excellent chemical temperature resistance.For example, Isolators may be used to provide electric motor bearings with an extra layer of protection against contaminants.
Katz continued, “With the wide range of oil seals available on the market, our bearing team can provide the expert guidance needed when searching for the ideal oil seal. No matter how unusual or complex the application, Emerson Bearing will find a solution for the customer’s exact needs.”
Emersonbearing.com
Filed Under: Uncategorized
