Rugged, double acting clamping products from Fabco-Air have single or double-sided clamp arms with choice of CW or CCW rotation. Clamp arm extends straight up as it releases work piece, then rotates 90° away providing easy access for loading and unloading. When clamping, the arm rotates 90° back, then retracts straight down to the clamp position. Offered in 5 bore sizes 25mm through 63mm, clamps have threaded body or square base mounting styles. Maximum operating pressures: 100-psi pneumatic models; 1000-psi hydraulic models. Request Catalog #FML.H.
Fabco-Air, Inc.
www.fabco-air.com
Filed Under: Hydraulic equipment + components, Pneumatic equipment + components, Pneumatic Tips
