Flexible coupling resists distortion, corrosion
By Mary Gannon | June 5, 2013
Coupling Tips
ERB series of flexible couplings from Autonics is made of super-high strength aluminum alloy (AL 7075-T6), which provides distortion resistance and  high torsional stiffness. An alumite surface treatment also provides high corrosion resistance.
The series supports two different connection types—clamp type and set screw type—that deliver more accurate revolution driving power and protect revolving objects from backlash.
Four models are rated for 6000 to 20,000 rpm and torques of 0.6 or 1.5 N (maximum of of 1.2 or 3.0 N).
Autonics Corp.
www.autonics.com
Filed Under: Coupling Tips
Tagged With: autonics
KTR EVOLASTIC highly flexible coupling
PTDA Webinar: Transform Your Sales Data to Identify PT/MC Revenue ‘Sweet Spots”
ComInTec torsionally rigid spacer shaft coupling with flexible bellow element
ComInTec “GD” gear coupling
