Designing a conveyor system to your specific application needs continues to get easier. Glide-Line ™, a developer of material handling equipment, offers a versatile multi-strand panel and pallet-handling conveyor system. The company offers configuration tools that streamline the design experience, ensuring a Glide-Line conveyor will meet your exact specifications.
Plus, with the conveyor systems’ modular design and simple construction, units and parts can be built and shipped in days, not weeks. The automated configuration tools generate real-time part numbers and pricing, as well as complete assembly information packages, making it possible to rapidly deploy.
Glide-Line also has its own manufacturing processes to make the conveyor components in house. It supports highly configured or customized designs quickly and just in time for assembly.
Conveyor dimensions include a drive shaft of 14 mm, end roller of 28 mm, drive pulley of 5 mm pitch and 40 tooth. A B14 flange motor moves the conveyor at a speed of 218 fpm.
The 24 VDC direct drive option delivers ultra-quiet maintenance free operation. There is no need for a gearbox and connecting shafts, which increases design flexibility.
All rolling elements are precision ball bearing supported for long ultra-quiet, high-load maintenance free operation. All Glide-Line systems use T5 timing belts with steel tension members for positive drive, durability and reduced maintenance
And you have multiple, mounting drive configurations in AC single, 3 phase options, as well as 24 VDC options.
Glide-Line
Guide-line.com
Filed Under: Bearings, Motors • dc
