All Metric Small Parts (aMsp) announces the availability of 12 off-the-shelf metric spring steel HRC 46-52 grooveless retaining rings. These rings have a black oxide finish and can be identified as the MKA5DNMGR555…Series. These retaining rings are for grooveless use and can be used for external axial assembly. In the series, the 12 different retaining rings are designed to fit shaft diameters of from 2 mm to 20 mm. Their allowable axial load ranges from 50N to 750N.
A more detailed 3-D CAD view of these 12 grooveless Metric retaining rings can be obtained from the aMsp Web site. You may also look up pricing and other retaining rings (external, internal) found at the aMsp online eStore. You can browse through the various selections of products 24 hours a day 7 days a week. aMsp offers an extensive array of all Metric standard industrial machine components. Their products include: knobs, door latches, panel latches, cabinet latches, boat latches, pull handles, handwheels, cranks, grips levers, locks, catches, hinges, screws, washers, springs, keys, plungers, and leveling & support feet. All of these are 100% RoHS compliant products.
http://allmetricsmallparts.com/press/retainingrings.htm
Filed Under: ASSEMBLY, AUTOMATION, MECHANICAL POWER TRANSMISSION
