The AutomationDirect line of inductive proximity sensors now includes additional harsh duty sensors and new standard duty sensors with quadruple sensing ranges. Contrinex DW series 4mm, 5mm, 8mm, and 12mm diameter round body inductive proximity sensors have been added.
Intended for harsh duty applications, 4mm smooth and 5mm (M5 threaded) models are available with full stainless steel housings.
8mm and 12mm diameter DW series sensor models are now available with quadruple sensing ranges. The 8mm M8 sensor has a 4mm (shielded) sensing distance and the 12mm M12 sensor has an 8mm (shielded) sensing distance.
DW series proximity sensors have an LED status indicator and are available with NPN or PNP, Normally-Open or Normally-Closed outputs. DW series sensors are IP67 protection rated and provide complete overload protection. All sensors are cULus approved, CE compliant and have a lifetime warranty.
AutomationDirect offers a complete line of sensors and encoders for proximity, pressure, temperature, level, flow, current and voltage sensing applications.
AutomationDirect
www.automationdirect.com/proximity
Filed Under: Sensor Tips
Jacob Goona says
Very interesting article !
I was wondering if anyone knew about how proximity sensors are used in smart phones. Found this article that briefly touches on it https://www.derf.com/an-overview-on-proximity-sensors/ but didn’t know if anyone had more information regarding that. This article I linked only talks about it briefly.
Best,
