EXAIR (www.exair.com) has specifically developed Model 1108SS Atto Super Air Nozzle to deliver the highest performance attainable from a tiny nozzle.
Engineered to minimize compressed air consumption while maximizing entertainment of room air, the Atto Super Air Nozzle provides the smallest, most precise blowoff together with a highly focused and forceful blast of airflow.
Packing the punch of strong blowing force, the compact nozzle can fit into tight spaces as it measures 0.50 inches (12.7 mm) in length and just 0.16 inches (4 mm) in diameter. It delivers a forceful narrowly focused air pattern that measures 1.0 inch in diameter when placed six inches away from the targeted surface.
The compressed air is ejected via a series of holes found in the recessed grooves on the nozzle surface. As required by OSHA standard 1910.242(b), the company assures safe operation since the airflow exiting from the nozzle cannot be blocked.
Aside from providing a narrowly focused air pattern, the Model 1108SS Atto Super Air Nozzle also delivers a highly amplified airflow and a strong blowing force of up to 2.0 ounces (56.7 grams) at a minimal air consumption of just 2.5 SCFM at 80 PSIG.
Designed to replace existing open pipes or wasteful nozzles, EXAIR’s Atto Super Air Nozzle features a Type 316 stainless steel construction which makes it ideally suited for cooling, blowoff and drying applications found in general industrial, food, corrosive, semiconductor, pharmaceutical or high temperature environments.
Filed Under: Food + beverage, Pneumatic Tips
