High speed
LINAK introduces a high speed electric actuator. This speedy actuator, built on the LINAK LA36 actuator platform with a speed of up to 6.3 in/second (160 mm/sec) without a load and a maximum force of 112 lbs (500 N), is a revolutionary addition to the LINAK product range.
High force
In September, LINAK will introduce a high force version of the LA36 actuator with a maximum load of 2247 lbs (10000 N).
This unique actuator eliminates many prejudices against electrical solutions and their limitations. Lifting 2200 lbs with a 36, 24 or 12 V DC motor is an extreme demand on both the mechanics and the electronics. LINAK has solved this problem by improving and strengthening the already robust design of the LA36 actuator.
:: Design World ::
Filed Under: Actuators
