Kar-Tech’s solid-state, dual-axis, encapsulated inclinometer module provides two axes of inclination over both J1939 and discrete analog outputs simultaneously. The 4–20mA analog outputs can be scaled (over CAN) for each axis of inclination. It is factory programmed for ±90°, 4–20 mA single axis vertical mount and ±45°, 4–20 mA dual axis flat (horizontal) mount running off of power between 9–30VDC. External connections are made via 6″ of shielded cable terminated in flying leads coming out of the module.
kar-tech.com
