Designed primarily to showcase mechanical motion during a trade show, this new kinetic gear sculpture from SDP/SI illustrates mechanical motion principles. It was designed and arranged by Andrea Davide, a New York-based artist who specializes in creating unique metal sculptures. Check out the video; this is a good way to show mechanical motion principles, whether at a show or in an educational institution.
Robert Lindemann, the recently retired Vice President of SDP designed the mechanical drive system that allows the gears to move properly. The motion is driven by an AC gearmotor inside of a large rectangular base, which rotates the smaller circular base on top. The two sprockets attached to the base are driven by bevel gears in mesh with a larger stationary bevel gear inside the base. The sprockets in turn drive the roller chain wrapped around the clear circular disks. The rotation of the circular disks about their center shaft is translated to the center gears inside, which in turn moves the entire geartrain.
Stock Drive Products/Sterling Instrument (SDP/SI)
www.sdp-si.com
