The REVOLEX KX-D SPLIT consists of hub bodies separated into two halves.
This production procedure allows for radial assembly and disassembly of the torsionally flexible pin & bush coupling without dismounting driving and driven side. The coupling is screwed via block assembly.
Material: steel
Sizes: 150 to 355
Torques (TKN): 25,000 to 350,000 Nm
Radial assembly/disassembly without displacing the power packs
Maintenance-free
Compliant with ATEX (according to EU directive 2014/34/EU)
KTR
www.ktr.com
Filed Under: Coupling Tips
