Kubler A41 draw-wire mechanism with encoder
By Mike Santora | December 10, 2021
Draw-wire mechanism with encoder
The draw-wire mechanics A41 with absolute encoder excels with its compact construction.
These draw-wire mechanics can be equipped with multiturn encoders of the F366x and M366x series. The maximum measuring length is 2 meters.
Kubler-A41-product-shotKubler- A41-product-shotCompact and simple
  • Measuring length up to 2000 mm.
  • Scalable analog output with limit switch function.
  • For applications with low traverse speeds.
  • Easy mounting.
  • Robust zinc die-cast housing.
Kubler
www.kuebler.com/en
Filed Under: Encoders (rotary) + resolvers
Tagged With: kubler
POSITAL’s explosion-proof rotary encoders receive ATEX/IECEx certification
z4636-F5858-Profinet-enc-std-srgb-web
New generation industrial ethernet encoders from Kubler
Sendix M3658 encoder with IO-Link interface
Kubler-B75-encoder
Kubler B75 draw wire encoder
