EXAIR’s new 1/2 NPT large external mix spray nozzles atomize fluids up to 303 gallons per hour. External mix nozzles are great where a high volume of liquid is needed. They can be used on liquids with a viscosity up to 800 cP. Large external mix nozzles are available in a narrow angle flat fan pattern. They combine liquid and compressed air to create a coating of liquid that can be easily adjusted to meet the needs of your application.
Key Features
- Coat, cool, treat, and paint a variety of products
- Used with water, atomizing nozzles are an efficient way to evenly cool hot items in your automated process
- Airflow and liquid flow can be controlled independently which provides the most precise liquid flow
- Stainless steel construction of these atomizing nozzles adds to their durability and corrosion resistance
- Atomizing nozzles are available in 1/4 and 1/2 NPT
