    • On the Floor
Linear position and speed sensing with rotary encoders
By Mike Santora | March 11, 2024
measuring-wheelPOSITAL’s measuring wheels and accessories, combined with the company’s versatile IXARC encoders, can be a convenient and accurate way of measuring linear motion in applications such as conveyer systems or the manufacture of rolled products. Recent enhancements to POSITAL’s programmable encoders have made it simpler to configure wheel-equipped encoders to meet users’ exact requirements.
“Encoders are great for measuring rotation”, comments Andy Zou, Product Manager at POSITAL. “But for many production processes, measurement of linear position or speed is what’s needed. Adding a measuring wheel to an IXARC rotary encoder produces a versatile tool
for making these measurements.” Wheel-encoder assemblies measure speed and position directly from a moving surface, avoiding errors due to gear backlash or hysteresis that can arise when encoders are connected directly to rollers or drives. For cut-to-length applications,
measuring product position directly from the surface of materials such as fabric, paper, wire, or sheet metal can improve accuracy and reduce scrap losses. POSITAL’s measuring wheel-encoder combinations provide resolutions as fine as 0.1 mm/pulse for all available wheel sizes.
POSITAL’s IXARC incremental encoders – the heart of the wheel/encoder set – are programmable. Resolution is defined by software parameters and can be modified with no changes to mechanical components. Commonly used resolutions, such as 1000, 1024, or 2048 PPR are available, along with resolution as high as 16,384 PPR. Likewise, output drivers can be set to either Push-Pull (HTL) or RS422 (TTL) to ensure compatibility with PLCs. In summary, POSITAL wheel/encoder sets can be customized to meet the exact requirements of each application. And, if production machinery is modified later, wheel/encoder sets can be re-configured on-site through simple software updates.
Measuring wheels are available with circumferences of 200 mm, 500 mm, or 12 inches. Four rim treatments are available: knurled aluminum, smooth polyurethane, and two tread patterns for the polyurethane tire. POSITAL also offers several spring-loaded mounting bracket and pivot arm assemblies designed to minimize slippage by maintaining a steady contact pressure between the wheel and a moving surface. Pivot arms can accommodate large lateral movements and feature adjustable spring tension for optimal contact pressure.
POSITAL
www.posital.com
Filed Under: Encoders • linear
Tagged With: Posital-Fraba
  • Toyota goes all-in on humanoid robots
    • On the Floor
