Freeport NY – New low-profile linear shaft supports from Ondrives Corp. feature a unique removable top. Using top loading makes for easier assembly and accurate re-alignment of shafts and bearings when needed with less downtime. The removable top allows quick replacement without the loss of alignment position.
These patent-pending LPB shaft supports are also low profile, only 0.87-in. high for a 0.25-in. shaft diameter. For shaft diameters from 0.25 to 2.0 in., there are 9 different sizes available. Metric bores are also available. The LPB shaft supports are also RoHS compliant and are precision manufactured in aluminum, are gray anodized, and have alloy steel fasteners.
Find more information here: http://ondrivesUS.com/support_LPB.htm
