    • Subscribe!
Long Range Autonomous Underwater Vehicle
By atesmeh | December 13, 2012
Using AllMotion miniature motor controls, a new research vehicle explores the upper water column of the ocean without the large footprint of an oversized propeller-driven AUV.
The Monterey Bay Aquarium Research Institute (MBARI) has developed the Tethys, long-range autonomous underwater vehicle (LRAUV) as a tool for ocean scientists. The Packard Foundation was instrumental in supporting the development of the Tethys from the beginning. The range and endurance of the Tethys expands the types of observations and experiments that are possible with autonomous platforms.
According to Brian Kieft, Software Engineer at the MBARI, “The Tethys LRAUV was designed to fill the gap between the large propeller-driven AUV models presently used, and the long endurance, low-payload buoyancy-driven systems.” The Tethys system, which incorporates EZSV23 AllMotion controllers, was designed specifically to operate for as long as a month in order to explore and map both chemical and biological features in the upper 300 meters of the ocean.
A suite of installed sensors will be able to travel inside the Tethys ten times farther than presently possible with present long endurance models. This expands researchers’ non-ship observational capabilities beyond the upwelling shadow and well into the oligotrophic (nutrient poor) ocean. For example, with this new technology, scientists will be able to study phytoplankton blooms for an entire cycle, from bloom-to-bust, by providing a mobile platform that can survey the bloom during its two-week to month-long lifetime.
An important design goal was to allow the Tethys to control its pitch and yaw using active control surfaces. Brian and his team also wanted to be able to control pitch by shifting the internal battery mass fore and aft inside the pressure hull. A variable ballast system allows Tethys to actively adjust its buoyancy, while a high-efficiency propeller drive system enables it to operate in ranges of over 1800 kilometers, while traveling at speeds of up to two knots.
Extensive design efforts went into minimizing the propulsion power requirements for the unit, which is about 12 inches in diameter, 7.5 feet long, and weighs about 265 pounds. Strategies included reducing drag through the development of a low-drag after-body, minimizing appendages, and developing control strategies to minimize induced drag. A custom propeller design and gearless propulsion motor optimized for efficient low-speed operations helped in these efforts. Of course, this uniqueness of design for the LRAUV unit required that it be custom built. So that the customization didn’t become a problem, Brian explains, “We used proven commercial components whenever possible to assure long life and accurate operation.”
Controlling Motion in the Tethys
The Tethys LRAUV is equipped with five actuators used to shift the battery mass, pump oil for buoyancy control, actuate the rudder and elevator, and operate the propeller motor. All five of these critical operations are controlled using All Motion’s EZSV23 EZ Servo Motor Controllers. Brian said that the “most attractive feature” of the EZ Servo Controllers was their flexibility to accommodate a variety of different styles of motor control, including analog position feedback, encoder feedback, hall sensor velocity feedback, and homing, to name a few. “We were also able to integrate one component for several different control systems early in the design process,” Brian said, “so the design team was able to move forward and focus on the custom portions of the overall mechanical design.
The EZSV23 is designed to implement brushed or brushless DC motor solutions in automation products within a short design cycle. These compact intelligent controllers measure only 2.25-inches square; operate from 12-40 volts through RS232, RS485, or USB-based communications; and were easy to integrate for the Tethys project.
A single, 4-wire bus links with up to sixteen 5-amp motors in a daisy chain format. Because commands can be delivered from any serial terminal program or from the EZServo/Stepper Windows application, a first time user can make a brushless DC servo motor move intelligently in less than half an hour. Plus, the device is capable of stand-alone operation, and can be set up to execute a preset string of commands upon power-up.
Between the five subsystems, the LRAUV exercises nearly every available operating mode provided by the EZSV23 controllers except for slaving. When this amount of control is coupled with power control (the EZ Servos are powered down when not actively controlling a motor) it highlighted additional areas the engineering team were able to explore, such as commanding a negative encoder value without changing position immediately following a power cycle. Basic operations for the LRAUV were easy to program into the unit, and integration into the vehicle control system proved to be fast and simple, with minor semicustom firmware modifications.
“In all, the EZSV23 controllers provided the right amount of functionality for our needs,” Brian said. The devices are highly reliable and can handle the often-turbulent environment that the Tethys runs into on the ocean surface. Being able to control the Tethys is imperative to gaining high quality data, and in order to do that you need the right controllers. All Motion was able to fill the needs of the MBARI team.
For more information visit www.mbari.org and www.allmotion.com.
Author Bio: Terry Persun is a Technology Journalist, and holds a Bachelor’s of Science as well as an MA in Creative Writing. He has worked as an engineer as well as a marketing consultant. Seven of his novels have been published. His science fiction novel “Cathedral of Dreams” was a ForeWord magazine Book of the Year finalist. His latest novel is “Revision 7: DNA”.
PCB mills
    • Subscribe!
