MICROMO Introduces the New FAULHABER 17/1 Series Planetary Gearhead
By Frank Tobe | January 31, 2014
Thanks to the sturdy construction, the FAULHABER metal Planetary Gearheads are ideal for applications which demand the highest torque. The new 17/1 gearhead is the latest addition to the FAULHABER gearhead product line in the 16 to 20 mm diameter range. The 17/1 gearhead is available with up to five gear speeds, with standard reductions of 3.33 : 1 to 1,367 : 1.
The 17/1 series, with a diameter of 17 mm and , stainless steel housing as well as steel and hard metal Planetary Gearheads and pins, is designed for continuous torque of 550 mNm and short-term loads of up to 800 mNm. Sintered bearings ensure axial shaft clearances under 0.1 mm. With the version with pre-loaded ball bearing, this can be reduced (to 0 mm, if necessary). The operating temperature range is between +100 and –30 °C by default. The gearhead is also available as a low-temperature model for requirements down to –40 °C.
For more information, please contact the MICROMO Team today.
MICROMO
www.micromo.com
Motion Control Tips
Tagged With: MICROMO
