Miki Pulley’s BXR-LE electric spring applied brakes are suitable for small and precise servo motor configurations. Their unique compact and lightweight design optimizes servo drive performance and efficiency.
With accompanying voltage controller, the brake’s power consumption is stepped down to 7VDC after a split second of 24VDC for brake actuation. When compared to most other electric brakes, the BXR-LE design provides just one-third power consumption and heat generation in one-half the overall size thickness.
Specifications:
- Maximum RPM: 6000
- Static friction torque range: 0.044 to 2.36 ft.lb. (0.06 to 3.20 Nm)
- Ambient operating temperature 14° – 104°F(-10° to 40°C)
Additional applications:
- End effectors.
- Ball screw actuators.
- XYZ positioning tables.
- 3D printers
Miki Pulley
www.mikipulley.co
Filed Under: 3D printing • additive manufacturing • stereolithography, Motion Control Tips
