Mobile Temperature System Brings Flexibility and Speed
By Test and Measurement Editor | October 17, 2013
InTEST Thermal, a mobile temperature control system for high-speed thermal testing of electronics, sensors and assemblies has been introduced by inTEST Thermal.
The Thermostream® ATS-535 brings temperature to the test site by directing a stream of cooled or heated air, reaching temperatures between -60 to +225°C very quickly. Highly mobile, without the need for an external air supply, it can execute fast temperature transitions e.g. -40 to +125°C in 12 sec. This allows for thermal characterization at the test site, for example, rather than moving the test subject to a thermal chamber or custom engineered enclosure.
The Thermostream’s swivel arm and hydraulic controls allow precise connection with the device under test. System setup and control is accomplished via a controller with adjustable positioning for convenient local operation, as well as connectivity for remote operation.
ATS-535 provides a convenient thermal source for temperature testing and conditioning of small-mass test subjects in design and production environments.
InTEST Thermal
www.intestthermal.com
The post Mobile Temperature System Brings Flexibility and Speed appeared first on Test & Measurement Tips.
Tagged With: intestthermal
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
