Muncie Power’s application suite, M-Power Spec, currently utilizes modern technology to quickly and easily specify wet line kits, power take-offs, pumps and clutch pump mounting kits by application. In addition, they announced the launching of our new Cylinder Spec module.
Users of this new module will discover its speed and reliability in selecting proper bore diameter, number of stages and stroke size. A part number will be configured with links to the appropriate literature (data sheets, brochure, etc.) and you then have the choice to print, email or text message the specifications directly through the module.
The Cylinder Spec Module also includes a competitor crossover feature which gives users the ability to convert their existing part numbers to Muncie part numbers.
Muncie Power
www.munciepower.com
Filed Under: Hydraulic equipment + components, ENGINEERING SOFTWARE, Mobile Hydraulic Tips
