Crystek’s CVCO55CC-2756-2756 VCO (Voltage Controlled Oscillator) operates at 2756 MHz with a control voltage range of 0.5V~4.5V. This VCO features a typical phase noise of -116 dBc/Hz @ 10KHz offset and has excellent linearity.
Output power Engineered and manufactured in the USA, the model CVCO55CC-2756-2756 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 5V, with a max. current consumption of 28 mA. Pulling and Pushing are minimized to 1 MHz and 0.2 MHz/V, respectively. Second harmonic suppression is -15 dBc typical.
The CVCO55CC-2756-2756 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
For pricing details, contact Crystek Corporation.
Crystek
www.crystek.com
Filed Under: Power supplies, Power Electronic Tips
