Add-on MapleSim Connector for LabVIEW and National Instruments (NI) VeriStand Software lets you manage complex engineering models. The software upgrade extends connectivity to hardware-in-the-loop (HIL) products from NI. This add-on also lets you connect to the new NI VeriStand product – a ready-to-use software environment for configuring real-time testing applications, including HIL test systems.
The MapleSim Connector for LabVIEW and NI VeriStand Software lets you export MapleSim models as code blocks, so you can include them in your LabVIEW VIs and NI VeriStand applications. This example shows a double-wishbone suspension assembly model developed in MapleSim and running in NI VeriStand.
Key benefits of this product include:
• Complex engineering system models can be developed and optimized in MapleSim.
• MapleSim models can be converted to user-code blocks for easy inclusion in LabVIEW VIs and NI VeriStand applications.
• Model code is fully optimized for high-speed real-time simulation, so you can perform HIL testing.
• All products are available from the Maplesoft Web Store or Maplesoft resellers.
Maplesoft
www.maplesoft.com
Filed Under: Software • 3D CAD, ENGINEERING SOFTWARE
