Amphenol RF is pleased to introduce new and improved SMA and N-Type coaxial connectors that have been optimized for Low Loss cables. These connectors are ideal for applications requiring high reliability and low signal loss. Common applications include telecommunication networks, antennas, wireless systems and broadband communications.
The new SMA and N-Type connectors are available in straight jack, bulkhead jack, right angle plug and straight plug configurations. They feature a crimp outer attachment using standard hex crimp sizes, allowing for quick and secure connections, provide consistent electrical performance at high frequencies and feature improved grounding for more stable RF performance.
Low Loss cables incorporate additional shielding in the form of a bonded foil conductor, which helps to improve grounding. The cables and the newly optimized connectors are matched to 50 Ohm impedance, allowing for maximum and reliable signal transfer.
The post New connectors optimized for Low Loss cables appeared first on Connector Tips.
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies, Connector Tips, MOTION CONTROL
