New generation industrial ethernet encoders from Kubler
By Mike Santora | December 17, 2021
z4636-F5858-Profinet-enc-std-srgb-webNew generation Industrial Ethernet encoders with PROFINET IO interface.
The optical absolute Sendix F58 PROFINET IO encoder is ideal for real-time applications. Thanks to the new technical platform, the encoder can also be integrated in PROFIdrive networks. The vertical communication, from control level to industrial production facilities, enables location-independent parameterization, remote diagnosis as well as priority-assisted process data exchange. Even maintenance work can be done in less time.
Latest PROFINET functionality
PROFINET IO, RT, IRT
Supports isochronous mode
Latest encoder profile (V 4.2)
Supports isochronous cycle times of a send cycle up to 250 μs and a jitter < 1 μs
PROFIdrive profile
Reliable and robust
Integration in applications with different performance requirements
Can be implemented in networks for tough realtime requirements with cycle times < 1 ms
Complete support for all Profinet features
Ideal for highly synchronous applications such as axis synchronization
Interoperability between diverse control and drive manufacturers thanks to PROFIdrive
Kubler
www.kuebler.com/en
Filed Under: Encoders (rotary) + resolvers
Tagged With: kubler
POSITAL’s explosion-proof rotary encoders receive ATEX/IECEx certification
Sendix M3658 encoder with IO-Link interface
Kubler- A41-product-shot
Kubler A41 draw-wire mechanism with encoder
Kubler-B75-encoder
Kubler B75 draw wire encoder
