(Dayton, OH) — SICK STEGMANN, INC. introduces DFS 60 Incremental Encoders. These hollow shaft encoders deliver from 1 to 65,536 ppr in an industry-standard 60mm housing – truly unrivaled resolution when compared with any encoder in its class. Typical 60mm encoders offer 1024 ppr, or up to 8192 ppr.
The DFS 60 is built on SICK STEGMANN’s new “F” Technology, the heart of which is a unique nickel code disc that provides significantly more robust operation and tolerance to higher temperatures than conventional optical encoders that typically have a glass or plastic rotating disc. This makes them an idea solution in heavy-duty industrial applications such as printing, textile, woodworking and packaging machines. DFS 60 encoders are IP65 rated and are available with a TTL or RS 422 interface.
Hollow shaft clamping provides easy mounting, reduces run out problems with collets and isolates electricity between the motor shaft and encoder. A radial/axial cable outlet reduces installation depth by up to 31% compared with similar encoder models, and allows a single encoder type to be used for various applications. An integrated stator coupling is housed in spring steel to increase bearing life, allow error free angle measurement, and allow users to adjust the shaft and axial movement of the motor shaft. A 30mm bearing distance results in maximized bearing life, very good run out, and minimum encoder vibration.
: Design World :
Filed Under: Encoders • optical, Encoders (rotary) + resolvers
