New network I/O Weldblocks from Balluff
By Andrew Zistler | February 17, 2016
unnamedBalluff is pleased to announce an entire new family of network I/O blocks optimized for extremely noisy electrical environments, such as welding. These new Balluff Weldblocks are constructed with fiberglass reinforced composite (polypropylene sulfide) that inherently resists weld spatter while effectively combats grounding loops and electromagnetic interference (EMI).
Weldblocks promote machine mount distributed modular architecture with IO-Link. The network node with IO-Link master on the Weldblock communicates over EtherNet/IP with the PLC or the controller of the machine, while the IO-Link ports can be connected to a variety of IO-Link enabled smart sensor devices or Balluff IO-Link I/O hubs.
The Weldblock family also includes I/O hubs with Balluff expansion ports to expand the total configurable I/O count per IO-Link port to 30, or the entire I/O count per network node to 240. Weldblocks from Balluff are equipped with a built-in enhanced webserver and port diagnostics to ensure quick troubleshooting. Add-On-Instructions for ease of integration with various controller platforms are also available online for free from the Balluff website.
Balluff
balluff.us
Filed Under: I/O modules, Networks • connectivity • fieldbuses
Tagged With: baluff
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
