The new axial piston pump, type V40M-028H from HAWE Hydraulics is suitable for hydraulic fan controls in mobile machines. The pump will displace volumes up to 28-cm³/rev and is designed for maximum operating pressure of 380 bar and peak loads of 400 bar. The optional P1R1 controller features help the axial piston pump comply with emission stipulations defined by Tier 4 Final and Euro 6 standards. The P1R1, electronic pressure controller continually adjusts the pump so the fan’s cooling output is fine-tuned to the temperature of the machine’s engine. It increases pressure in the event of power failure, thus protecting the engine against overheating.
Combining the V40M-028H with valves from HAWE’s product portfolio enables implementation of more demanding fan control requirements. The pump can be mounted directly to the diesel engine and takes up very little space as it has a width of just 5.2-in. and a length of 7.2-in. Depending on the installation space within the machine and the need for cooling, multiple fans can be deployed independently of each other. The fans can be engaged in standard or reverse operations and run either in sequence or parallel to each other.
Hydraulic fan controls separate the fan and combustion engines’ speeds. By continuously adjusting the cooling output, the hydraulic control can also be configured to activate the fan once the machine’s engine has reached its operating temperature. In the case of cold external temperatures the fan will not be activated at all; this cuts down, not only fuel consumption, but also the machine’s noise emissions.
The V40M-028H is the second model within the axial piston pump series designed for applications with a pressure range up to 350 bar and a volume flow up to 80 l/min. HAWE offers customers efficient and complete solutions that allow this pump to be connected with a number of proportional directional spool valves and controllers – all from HAWE’s modular constructed product line.
HAWE
haweusa.com
Filed Under: Hydraulic equipment + components
